It is currently Mon Jul 21, 2025 2:59 pm
PostPosted: Fri Feb 16, 2007 1:15 am
Anybody got one of these?
DIRECT LINK
I need a down draft solution and soon. My Delta downdraft table attached to a cyclone dust collector ain't worth a hill of beans!
Any thoughts?
PostPosted: Fri Feb 16, 2007 1:31 am
Hesh that is a great idea and one that I will do if I get this machine.
By the way, I will be at work tomorrow, want me to bring the jet with me?
PostPosted: Fri Feb 16, 2007 1:49 am
Lance,
   I have that Grizzl table and it works great! I actually picked it up when I
made the switch from nitro lacquer to the UV cured poly finish. The UV
finish creates clouds of dust when sanded so I needed a dedicated
solution and the down draft table was just what i needed.
   Those walls that help to contain and direct the draft actually unclip and
fold down out of the way to give a flat, open table top to work on. The
rubber grommets that protect the pieces you work from the edges of the
draft holes do a nice job too. The motor creates a really nice draft, but
you'll find that it's best to keep a few extra filters on hand.
    I'm actually going to vent it directly outside to eliminate the need for
the filters altogether.
    I'd recommend it to anyone.
Regards,
Kevin Gallagher/Omega Guitars
PostPosted: Fri Feb 16, 2007 2:10 am
Thanks Kevin!
That is what I needed to hear!
PostPosted: Fri Feb 16, 2007 2:20 am
That didn't take much (but coming from Kevin, you know there's wisdom there)
MMMMPPPPAAAAAAA (that's a virtual Darth Vadder breath) TAS is strong with this one! MMMMPPPPPPAAAAAA
PostPosted: Fri Feb 16, 2007 5:34 am
I used one of these tables at my old job and it worked well if you remember to clean the filters. One gripe I had was the little rubber grommets. They like to fall out and when sanding just a top or a back or anything flat and thin, the piece would flex some between the rubber grommets. It was not my machine so I didnt modify it to stop the flex but maybe taking all the grommets out and putting down a flat surface that dust can go through would be a good idea.
Blake
PostPosted: Fri Feb 16, 2007 5:41 am
Thanks Blake, that makes sense,
Maybe a flat board the size of your sanding piece, back, top or side would stiffen it for a better sanding surface..
Good tip! Thanks!
PostPosted: Fri Feb 16, 2007 7:41 am
You could lay a piece of pegboard over it. Already has the holes in it. I saw one like that somewhere.
